8800gt and 1920x1200
460 Views 10 Replies 8 Participants Last post by  pez
Should my gpu be able to handle this resolution in gaming? In dirt, when it gets busy on screen, and all settings on low I get wicked frame stutters to the point it makes the levels unplayable unless Im on clubman. It only happens whens there a lot of cars on screen, and this is single player.
Edit, forgot to mention, have reinstalled sound and gfx drivers with a driver cleaner in between, did not help.
1 - 11 of 11 Posts
Well from your frame stutters I'm guessing your cards VRAM is 512mb. You might wanna consider getting a card with 1GB of VRAM.
4850 and 9800GT would both be excellent choices (mid-high range cards)
It's going to be hard for a single GT to be able to push many games at that high a resolution. Add another for SLi, or get a faster single card.
Wish I could sli, but I have a crossfire board. Would be so much cheaper than buying a better faster card. But thats what I figured was the problem, and thanks for the confirmation guys.
need more horsepower!
The 9800GT = 8800GT so that wouldn't help at all..
Yeah, why not go for a hd 4850 and then you can crossfire them down the line.
get a 4870 1gb and be done with upgrading for a while
qft
Because thats $200 or so I dont have
Well just hold off and save a bit longer. It would be worth the wait.
1 - 11 of 11 Posts
