Turned on my PC this morning and now the 8800's fan scrapes the shroud and the only way to make it stop the blasted noise is to tap the center of the fan.... I can't seam to pull off the shroud because it has metal tabs on it that are impossible to pry up on
... Any suggestions on how to fix this problem?
It's the BFG OC version if that helps...
Also, if anyone has a 8800gts 512nmb cooler, or a 9800gt or 8800gt cooler or even a duorb for sale, It'd be much appreciated if you could contact me because if this can't be fixed easily, I need to get a replacement.
