1 - 10 of 10 Posts
Hi,
Is two EVGA 8800 GTS 512 SSC good enough for high-end gaming on a 24" Monitor?
EVGA 780i
Q9550
2GB DDR2-1066
or Shall I buy a 22" 1680x1050?
Originally Posted by bretto22
yep should be fine, ull get better performance with 22" tho
imho 22" is big enough for how close you sit anyway..
kind regards!
Thanks,
anyone using two 8800GTS 512s on 1920x1200 ?
Two of them would be overkill on 1680x1050. Thats what I used to run, and apart from a few games, a single card will max out anything.
1920x1200 is another story - at this resolution 2 cards would be perfect.
For 1920x1200 go with a card with a more memory than 512MB, the performance isn't horrible but it is a bit smoother with the extra memory. Unfortunately in SLI the onboard memory for only one card is used. A single 8800GTS 512MB, would give you some pretty good fps on a 22" monitor.
A single gts 512 struggles at 1680x1050 on some of the newer games. Namely Stalker: clear sky did not perform very well with a single gts 512.
Originally Posted by beatrix View Post
Thanks,
I'm using 1 8800GTS 512 on a 1920x1200 and it runs everything I play very well. I have both 22" and 24" monitors and I highly suggest going with the 24" if you can. The higher resolution is nice and the larger screen makes gaming a little bit more involving.
http://www.guru3d.com/article/stalke...ance-roundup/4
The 8800gt doesn't seem to be struggling that much, 8800gts 512 is a better card.
I use a single 8800GTS on my 24in monitor and its fine. 2 will be more than enough. I would suggest getting a 24in monitor, there is a big difference between 22 and 24in, not just the size but the full HD.
1 - 10 of 10 Posts
