8800GTS 640Mb Thinking of getting it...
684 Views 11 Replies 4 Participants Last post by  Anth0789
Well for some reason ive changed my mind on getting the 8800GTS 320Mb im thinking of getting the 640Mb instead for more performance
But is the power supply that i might be getting strong enough for it?After i get the power supply then ill probably get the 8800GTS 640Mb soon.
This is the PSU
http://www.newegg.com/Product/Produc...82E16817341001
But can it handle the 8800GTS 640Mb???
1 - 12 of 12 Posts
Yes that PSU will be fine with that card mate. Also the 640 is a better choice due to the fact that later I beleive games to utilize the extra memory
I personally own the PSU and GPU and they run great with each other. Even with my GTS overclocked to 655/1020, the PSU is able to handle its power and my entire rig.
Okay Thanks
I got another question...Do you think it will fit in my case? lol im not sure..There's some space a bit.
Because you are a good member
I am going to do you a deal, smile and you can have the 700W version for an extra $5
Click me
And yes both will power the card perfectly. Even in SLI
It'll fit perfectly!
I still have room in my case.
Click me
Yeah Thanks ill get a 700W instead.
Well that answers my questions
Thanks a bunch guys
I just got my PSU today!! its awesome my pc cools more now
,Next is the GPU
1 - 12 of 12 Posts
