Originally Posted by hermit
somebody have a video of the installation process. the thermalright website have it pretty much detailed with pictures, but i want to see a video
and does it come with the 'glue' to stick the ramsink on the chips?
thanks
Couldn't find a video; the installation guide (which you're most likely talking about) is pretty much the closest installing specifics you're going to get.
The ramsinks come with thermal tape, although it is fairly weak. You're better off with thermal adhesive (glue basically).
Can you run SLI with any of these enormocoolers on there? Or is that a foregone conclusion?
If you get a motherboard like the eVGA 680i it should fit, but you won't be able to use anything else at all, all the PCI slots will be blocked as far as I know.
