hi..
i got a small problem that i need to clear before i by a 8800GTS..
ok here goes ..
i own a 8800GTS the memory clock speed on the one i own is 1.8GHZ
the one i'm going to by is 1.6GHZ memory clok..what i wont to know is will the two cards work in sli..
here is the links you can look at ..
i own this card
http://www.shopmagenta.com/store/pro...813.aspx?sec=1
it has a 1.8GHZ memory clock..
this is the card i wont to by..
http://www.shopmagenta.com/store/pro...AU1024452.aspx
..sorry for eny spelling errors..
ok here goes ..
i own this card
