It is not so easy. You need very steady hands and a very fine soldering iron and a magnifying glass (experience is needed)
But here is the link if you want to try
http://www.madshrimps.be/?action=get...194&howtoID=72
You can also check out my gallery I have a pic of the sli vmod
710/2196 60c Max on water
I still have more head room on the Vcore volts just under 1.4V stock 1.33V
With the Mod link above it limits the mem to just under 2.0V but the Vcore can go all the way to 1.47V but after about 700mhz on the core the performance does not scale up that well. There seems to be a wall to stop GTS clocking past the GTX
But since you are not concerned about your card I say go for broke
