It depends on the timings and what you do.
Gaming, rendering, etc.
Full 8gbs?Originally Posted by jonespwns;13077036
I've been playinga game called All Points Bulletin and it maxes out my RAM. ALL THE WAY. so thats why ive been sorta wondering
noo i meant when i had 4GBs lol. When i used 4gbs of ram it was like ALL of it. thats why i put the extra 4gbs in thereOriginally Posted by Shomiyamu!;13077054
Full 8gbs?
What?
You sure you're not running like 8 instances of those games at once? (Kidding of course)
Don't mix ram?
Ah.Originally Posted by jonespwns;13077072
I just went into my bios and set them both to 5 5 5 18. For some reason bios had them running at a different timing.Originally Posted by Shomiyamu!;13077088
Ah.
But it still wouldn't fill it up if you're just gaming.
Weird.
If it's mixed ram you might want to make sure that the timings are the same or else one set will dumb down to perform on par with the other set.![]()
Now you're good assuming they're at 800mhzOriginally Posted by jonespwns;13077215
