1 - 5 of 5 Posts
Hi, i am trying to make two 8pin connectors. I have two six pins and was wondering if i could use the cables from a spare 4pin to make two 8pins which would power my gpu. The six pins had +2 cables but i removed them when i first sleeved my psu. Thanks.
Senior OCN Member
Which PSU?
AMD fan
it may and it may not work
if the connector had a +2 piece then it may work if you used the original one but, a make shift one is a gamble and could be very dangerous.
Senior OCN Member
It is a cooler master gx 650w.
Dont bother its not worth it
1 - 5 of 5 Posts
