Status
Not open for further replies.
1 - 2 of 2 Posts
http://www.giveawayoftheday.com/driv...glish-version/
Key features:
Windows 7 Support (32/64-bit). Accomplish any operation under Windows 7
Copy Features. Copy a full hard disk or a separate partition, and resize a partition while copying
Scheduling for copy operations. Set up a timetable for copy operations with new flexibility.
Refined User Interface. Improved two-level user interface (Easy/Advanced) to satisfy the needs of every customer.
Support for major virtual machines. MS Virtual PC, VMware Workstation, VMware Fusion.
Now support for Linux ExtFS, Apple HFS+.
Wide migration options. Migrate to another hard drive, migrate to different hardware, migrate to virtual machine, migrate your Apple hard drive.
P2V Copy. Migrate a Win2K+ physical system to a virtual environment.
P2P Adjust OS. Make OS start up after unsuccessful migration with 3rd party tools.
Simple Backup and Restore Wizard. Make the process of adding new drivers even more smooth and easy.
3 steps to make your system mobile with Drive Copy 10 Personal Special Edition:
1. Create a virtual clone on your PC. Including operating system, drivers and settings, all your applications and files.
2. You can choose the format of your virtual environment. Choose format you prefer â€"VMWARE or MS Virtual PC. New users can download a virtual player from the official site of preferred vendor for free.
3. Save a virtual clone of your PC to a USB hard drive. Save a virtual player on the same disk as well and use your PC anywhere.
Your PC is in your pocket now! Use Drive Copy 10 Personal Special Edition and easily migrate to new hard drive or even different hardware without reinstalling, create backup images of your hard drive, and perform basic partitioning operations and even more!
Detailed Product information is available at Paragon Drive Copy 10 Personal Edition website
Limitations: No WinPE included in this download
Technical Support: During the Giveaway period Paragon Software provides technical support at http://twitter.com/paragonsoftware. Please, post your questions if you have any troubles while downloading, registering and using the software. Paragon Software’s support team will reply you as soon as possible.
If you are x64 OS user please follow the link here (file size: 101 MB)
Reactions: npham858
1 - 2 of 2 Posts
Status
