1 - 20 of 27 Posts
Discussion Starter · #6 ·
This is in OCCT 15mins. Was told that was good enough with less then 20errors.
it seems like only my old msi cyclone is hitting those temps. I don't have it Oc'ed much either maybe to 1.0 voltage and 760 core.
Originally Posted by codejunki;11945868
Not enough info to decide
It's a 460. These cards run at like 60-65°C at stock, under 80°C overclocked. They should NEVER hit 90°C.
And don't use OCCT. I remember the OCCT GPU test practically cooked my 5850. I would max about 75°C in Furmark but the OCCT test toasted it to 90°C.
Use Crysis/Metro/3DMark for heat testing. It's realistic.
They do if they're sandwiched... which the OP has just stated they are.
Originally Posted by Confessed;11946418
My friend has SLI 470's sandwiched and they max out at 78°C in his HAF X.
My friend has dual 460 HAWKS Sandwiched and the first card runs 25C hotter than the 2nd card because of the sandwich. That's even with a Corsair 800D Case heh.
Reference 470s are alot better at dispersing heat from a sandwich rather than say a Twin Frozr II or a cyclone which disperses into the case.
Reference 470s are alot better at dispersing heat from a sandwich rather than say a Twin Frozr II.
800D is awful for air cooling...lol.
And for those who use multiple cards sandwiched, put the display on the bottom card. It will take some of the load off the top card and balance the temps more.
1 - 20 of 27 Posts
