9500GT Physx
1469 8
So while browsing fudzilla i've found this interesting thing , a a PCI-e x1 9500GT card. So my question is , will it be possible in theory to use this card as a physx accelerator with another Nvidia/ati card ?
1 - 9 of 9 Posts
That's interesting , and how much do those converters cost and what's the loss in performance(for physx as well) ?
Edit: or a dedicated physx pci card would be a better option and cheaper to get?
$8 from eBay (but you have to cut out the back).
I don't believe PhysX need much bandwidth since the Ageia PhysX PCIe card only has a x1 connection.
Reactions: Akisame
Efficiencycionado
wow. thanks +rep
also, how did you manage to screw that card to the case when it got taller?
Originally Posted by gerikoh View Post
wow. thanks +rep
I already responded in the other thread.
Reactions: gerikoh
Efficiencycionado
ok thanks. i'll try finding that as well. then buy a 9500gt. or is a 9400gt alread enough for physx?
Discussion Starter · #9 ·
Another question , is there any difference between 8400gs and 9800gt (any random 9 or 8 series) in terms of Physx performance or are the Processing unit for physx are the same on every card?
1 - 9 of 9 Posts
