955 worth getting over the 720?
11626 Views 56 Replies 20 Participants Last post by  youra6
all opinions/suggestions are welcomed!
1 - 20 of 57 Posts
Is it worth it to get a 720 to replace your 9950? Definitely.
I'm not sure if that's what you're asking, though.
sorry i made a huge typo i meant the 955 over the 720
The 955 beats the 720 in all benchmarks. Go with the 955, especially at the current price.
The 955 is worth if you are planning on using 4 cores. But if you're on a budget and can't get the 955, then get the 720 and hopeful you can unlock a core from there. Whatever you choose will be a good cpu.
Good luck!
well the thing is the 720 is within my budget. But if the difference is big enough, I will wait until I have enough for the 955 or 965 c3
It depends on what you plan on doing. If you do video editing and encoding, go with the quad core. If you game, get the tri core because most games aren't yet optimized for more than 2 cores. If you're lucky, you could unlock the 4th core and have a quad for the price of a tri!
But keep in mind while upgrading is what we all love to do here, it's not fun to do it too frequently. The 955 is going to benefit far more with multi-threaded apps and games, which is (for the most part) all that is being made right now. You are going to get better current and long-term results with the 955. I would say wait.
why do some of the unlocked cores end of being unstable? Is it like a botched sicence experiment aka the 720?
I see ur doing a bit of upgrading yourself.
Yeah, I'm going from 965 to i7 due to some issues I had with the 965. I still love the AMD chips and I've personally owned the 955. I'm biased of course to go with the 955, so I can't recommend anything less at this point.
The Phenom II x2/x3 dual and tri-core chips were originally quad core chips that had one or two bad cores (it happens, nothing is always perfect, especially in manufacturing) that they simply disabled, as the other 2 or 3 cores were fine. Better to sell them off as dual or tri cores rather than throw them away.
But to answer your question, I would just stick it out with the 720 if you're not going to use the extra core. It's better than a dual since you have the third core for multi-tasking, and it's still a very fast chip. If you an unlock the fourth core, then it's just a bonus.
thats kind of funny, almost like selling a faulty hardware. Im sure they still work fine though.
Its gonna be a tough decision
Either one will perform great, really. You don't actually need a quad for gaming.
yeah well if i happen to unlock that 4th core and everything runs dandy, how much faster would the 955 be if they were clocked the same. Let same 3.2 ghz?
And if the the 720 has only 95w compared to the 955 125w, how come the 720 cant clock as high? Is it because the 720 only has 3 cores?
Thanks!
ive seen 720's clocked around 3.6 to 3.8, but damn, your current cpu is holding back your 280's...
ive seen people get to 3.6 just by raising the voltages. But they hit a huge wall after 3.7- 3.8 which is kind of strange.
http://www.sharkyextreme.com/hardwar...61_3801711__11
This is not true. There are higher chips that did not pass specs so AMD disabled 1 core and labled them them 720's with a disabled core with lower specs. The cores are not bad or defective although some cannot unlock the 4th core. Some chips made it out and were able to unlock 4th core and......Overclock nicely.
my cpu would even hold back 1 280 not to mention in SLI
I say go with 720be and save for the 6 core coming out sometime next year.
1 - 20 of 57 Posts
