1 - 10 of 10 Posts
Ok, well my old computer which is now my friend's comp the system wont post. Everything boots up, but it just says no signal on the monitor. No beeps, no anything. When I take out the graphics card it does the same thing, a.k.a. nothing, no beeps no anything. It registers when the RAM is taken out though. Gah, help this is really frustrating, and I dont wanna let my friend down.
Can you hear if the hard drive is loading windows up?<br />
<br />
Or does the system not p.o.s.t.<br />
<br />
Doesn't sound good, maybe reseat everything for fun..
Try a different VGA/DVI cable....just a thought.
Hmmm, alot of bad video cards will post (my dead gf_mx2 did)<br />
<br />
I dunno mang, maybe try cleaning the gold teeth on the agp<br />
<br />
And try the card in a different machine, or try a different card.<br />
<br />
Reseat cpu for fun maybe,
You happen to have a spare PCI card laying around?<br><br>
Odd that it wont even beep. Usually it will have a post code if the graphics card is bad/missing.
Sounds more like the motherboard to me.
Discussion Starter #8
<tr>
<div>
Originally Posted by <strong>bigvaL</strong>
</div>
<div style="font-style:italic">Sounds more like the motherboard to me.</div>
</td>
</tr>
</table>
</div>Beginning to think that to.. It beeps if I take the RAM out though.. Maybe the AGP port is just bad?
well my sister's computer used to do the same thing. so i cleaned the AGP port out and it works fine now
Well might be a little off on this one, but I had a PS that went bad and wouldn't pull enough juice. Mobo beeped at me when I took the ram but that was about it. PS was the last thing I checked and didn't check that until after I put the board in a different box and everything came back up. Felt kind of stupid after that one. Just a thought though. What other cards are in there? Worked on one machine that had a modem in it, would turn on or anything until I removed that, came up right after that. I'd unplug everything but the monitor and PS and see what you get (that includes HD's, floppy, and CD-Roms off motherboard). If it post, then work from there.
1 - 10 of 10 Posts
