Hi all, new here and hopefully in the right section to ask.
I can get my Phenom II 965be to 4.0Ghz fine, and have been using it at that now for a couple of months with it going no higher than 44c
But as soon as I go to 4.2Ghz I start to get BSOD's when under load. Where can I go from here?
NZXT Phantom Case (IN 1 x 200mm Side, 1 x 120mm Side, 1 x 140mm Front, OUT 1 x 200mm Top, 1 x 140mm Rear)
990FXA-UD5 Mobo
AMD Phenom II 965be @ 4.0Ghz with Zalman CNPS 12X Cooler
Kingston HyperX Genesis DDR3 1600MHz 16GB
