1 - 20 of 30 Posts
Only need 221 point's for the 10,000 mark.<br><a href="http://assets.overclock.net.s3.amazonaws.com/c/c1/c186ee56_vbattach32653.jpeg"><img alt="LL" src="http://cdn.overclock.net/c/c1/525x525px-LL-c186ee56_vbattach32653.jpeg" style="width:525px;height:394px;"></a><br><a href="http://assets.overclock.net.s3.amazonaws.com/5/5e/5e101964_vbattach33246.jpeg"><img alt="LL" src="http://cdn.overclock.net/5/5e/525x525px-LL-5e101964_vbattach33246.jpeg" style="width:525px;height:420px;"></a>
Um...what bench?<br><br>
LOL<br><br>
I'm hoping your talking about 06...I broke 10,000..If you can do it, tis a great thing<br><br>
BTW, push your CPU more, then you'll def break 10,000
Loosening your timings will drop your socre. Any chance of pushing the CPU a tiny bit farther?<br><br>
Also, do you set it to "High" priority and close all other running non-neccessary tasks?
Discussion Starter #4
Sry 3d 06.I went all the way up to 710/856 and froze the 3d 06 program.<br><a href="http://assets.overclock.net.s3.amazonaws.com/d/d2/d2cb469d_vbattach32584.jpeg"><img alt="LL" src="http://cdn.overclock.net/d/d2/525x525px-LL-d2cb469d_vbattach32584.jpeg" style="width:525px;height:394px;"></a>
tighten the memory!
Discussion Starter #6
Im going to try go up in the cpu,Want to try to leave timming's the way they are.
Discussion Starter #7
still working on cpu @2.78<br><a href="http://assets.overclock.net.s3.amazonaws.com/c/cd/cd8bef73_vbattach32607.jpeg"><img src="http://www.overclock.net/image/id/617533/width/525/height/525/flags/LL"></a>
Discussion Starter #8
1 more run.Thinking change drivers.Using 91,47 now.
Do a suicide run on the RAM and CPU...will be stable just long enough to break 10,000 <img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" />
Discussion Starter #10
Thank's going to give a try.You have the 10,000?in your SLI?
<tr>
<div>
Originally Posted by <strong>alexisd</strong>
</div>
<div style="font-style:italic">Thank's going to give a try.You have the 10,000?in your SLI?</div>
</td>
</tr>
</table>
</div>Prior to Conroe, only AMD's could do that on the ASUS SLI. One of these days, I'll get a Conroe and "go for the gold".
Discussion Starter #12
Good luck and thank's.And go for the gold.
Discussion Starter #13
Last up date until some day reach the 10,000.No doubt beat most of SLI rig's even some of the GTX is a great card's.But with C2D is hard to beat the top gun's.<br><a href="http://assets.overclock.net.s3.amazonaws.com/6/63/635a39c9_vbattach32654.jpeg"><img alt="LL" src="http://cdn.overclock.net/6/63/525x525px-LL-635a39c9_vbattach32654.jpeg" style="width:525px;height:394px;"></a><br><a href="http://assets.overclock.net.s3.amazonaws.com/f/fa/fa393e91_vbattach33249.jpeg"><img alt="LL" src="http://cdn.overclock.net/f/fa/525x525px-LL-fa393e91_vbattach33249.jpeg" style="width:525px;height:420px;"></a>
Have you tried different drivers? I use 84.56s, but there's supposedly some new ones that are great.
I learned a little trick a while back. Type "<span style="color:#FF0000;">rundll32.exe advapi32.dll,ProcessIdleTasks</span>" in the run dialog before you run the benchmark. See what happens. <img alt="" class="inlineimg" src="/images/smilies/wink.gif" style="border:0px solid;" title="Wink"> (It helps the CPU score)
Discussion Starter #17
Thank's guy's I try some of the trick's,overvolt's cpu,norton out,none of the old drivers match the card's,only the 91.47 for now,im going to try the run dialog to see thank's all of you .
Power Squid
Nice scores, he's mine on a single 7950GX2 without any Vmods;<br><br><b>3DMark2006 - <i>9407</i></b><br><a href="http://service.futuremark.com/compare?3dm06=534717" target="_blank">http://service.futuremark.com/compare?3dm06=534717</a>
overclock the gpu a bit if you havent already that'll give you a nice performance jump.
Discussion Starter #20
Look like my card's that's the max working in the memory department to see if can go up in those scores.I did a fresh windows install would see.And you using the monster 6300 C2D.Nice
1 - 20 of 30 Posts
