21 - 30 of 30 Posts
Power Squid
<tr>
<div>
Originally Posted by <strong>alexisd</strong>
</div>
<div style="font-style:italic">Look like my card's that's the max working in the memory department to see if can go up in those scores.I did a fresh windows install would see.And you using the monster 6300 C2D.Nice</div>
</td>
</tr>
</table>
</div>E6600 <img src="/images/smilies/rolleyes.gif" border="0" alt="" title="Roll Eyes (Sarcastic)" class="inlineimg" /> <br />
<br />
If you've tried a fresh install and you card can't go higher then it looks like you're alrready topping out. as 3DMark2006 is heavily GPU intensive I don't think you'll be able to get that much more even if you overclock the CPU more.
Discussion Starter #22
testing link.<a href="http://service.futuremark.com/orb/projectdetails.jsp?projectType=6&XLID=9063508&UID=6612924" target="_blank">http://service.futuremark.com/orb/pr...08&UID=6612924</a>
Use 84.56 and install through control panel.<br />
Set your graphics card as a 7900GT.
Discussion Starter #24
I pass that one.Work if I put 7900GT because mine 7950GT is no there.
<tr>
<div>
Originally Posted by <strong>t4ct1c47</strong>
</div>
<div style="font-style:italic">as 3DMark2006 is heavily GPU intensive I don't think you'll be able to get that much more even if you overclock the CPU more.</div>
</td>
</tr>
</table>
</div>Overclocking your cpu won't help all that much in the FPS scores, but 1/3 of the test of 3m06 is CPU score. Overclocking your cpu another 200 mhz will give you about another 150 pts in that category, hence raising your overall score.<br />
<br />
I'm just pushing 10k with 2 7900gtx so 9.7k on a 7950 is pretty kick ass.
Discussion Starter #26
I went up in the cpu and gain some point's,the cpu is no stable @ 2.8 but I know is memory,mine memory the xms are @ max rigth now.Going to try my G.skills later this week as long I have to reset cmos don't want to do that today.And thank's for your comments. Want to run the g skills with no divider and x11 in the cpu to see if I can get the 10,000.And you run those benches @ 3.12?<br><a href="http://assets.overclock.net.s3.amazonaws.com/0/04/046b3115_vbattach33247.jpeg"><img src="http://www.overclock.net/image/id/617042/width/525/height/525/flags/LL"></a><br><a href="http://assets.overclock.net.s3.amazonaws.com/f/f5/f5e7043e_vbattach33248.jpeg"><img src="http://www.overclock.net/image/id/617041/width/525/height/525/flags/LL"></a>
<tr>
<div>
Originally Posted by <strong>FrankenPC</strong>
</div>
<div style="font-style:italic">Prior to Conroe, only AMD's could do that on the ASUS SLI. One of these days, I'll get a Conroe and "go for the gold".</div>
</td>
</tr>
</table>
</div>AMD + Crossfire worked darn nice also <img src="/images/smilies/wink.gif" border="0" alt="" title="Wink" class="inlineimg" /><br />
<br />
I got 10k with an Opty 170 at 2.9 GHz and dual X1900's. You should be able to get it at 2.9 or so.<br />
<br />
Here is my score of 10,098 with the Opty:<br />
<a href="http://service.futuremark.com/compare?3dm06=346565" target="_blank">http://service.futuremark.com/compare?3dm06=346565</a><br />
<br />
It seems to be the SM3.0 score that's holding you back. You beat my SM2.0 score and are close to my CPU score (which does not weigh too heavily). Iwould have expected better SM3.0 from 7950's. At this point, does not seem a whole lot better than volt modded 7900's
Discussion Starter #28
So far only in the top 30 GPU systems the s dumper and the viper use the 7900GT volt mod and beat the 7950GT S dumper with theC2D andViper @ 2.9 or so that mean,my case I think is memory related?Don't you think?
<div>Originally Posted by <strong>alexisd</strong></div>
<div style="font-style:italic;">And you run those benches @ 3.12?</div>
</td>
</tr></table></div>
Yah all those the benches I've put were at 3.12Ghz with ram at 4,4,3,4,11 @1040Mhz.
Discussion Starter #30
im @ 2.7 that's mean is no that bad.
21 - 30 of 30 Posts
