1 - 20 of 26 Posts
no.
450 is like a 250, 250 is like a gtx+, gtx+ is a faster gt.
not worth it. 460 768mb prices are dropping like flies! wait a bit and get a cheap 460.
Reactions: m3th0d
Originally Posted by redhat_ownage View Post
2 overclocked 8800gt = 460 without DX11
find yourself another 9800GT and sli
his mobo doesnt support SLI.
Originally Posted by LethalRise750 View Post
He can used modded drivers.
I mean physically. doesn't have a 2nd PCI-E x16.
Discussion Starter #10
460 aint worth it either
So you're saying I won't notice any improvement over a 9800 GT with a 460?
Reactions: m3th0d
Originally Posted by kora04 View Post
no.
Given that a 450 has 192 cores, and the 250 has about 128, isn't the 450 more like at least the early 260s?
PC Evangelist
Get a GTX460 and that would be a good upgrade. Double the memory, double the mem bandwidth, triple the SP. Also HD 5750 si faster then GTS450 its not worth it.
Reactions: m3th0d
No there will be a huge difference between the 460 and 9800gt. GTS 450 is a good card but its not the best you could do with a price range like that.
Old to Overclock.net
Go for the gtx460! I came from an 8800 GT sonic edition (and OC'D like hell) and I saw the difference in performance for all the games I play!. You also have to take into consideration that the 460's OC like hell reaching performance levels of the 470 (almost), it also beats the 5830 and ties and beats (depending on the game) the 5850.
That's pretty good bang for the buck if you ask me! now if he sells his 9800GT, he'll probably be paying less than $100 for the new 460, so I think it's worth it!
my two cents...
Reactions: m3th0d
At first I thought maybe it would be but considering you could get a GTX 260 216sp for around 110-120 its not that good of a deal, this thing is just too crippled.
Buy my 285
= 465
No dx 11 but still good card. i was going to use it as a phyicis card. But 2 480 in sli is better i think
450 not worth it. its more or less new pyisic card.
460 1 gb card is good. 460 758 is a pos.
I would say 460 1 gb .
The GTS 450 is a major upgrade to the 9800 Gt! No doubt about that, looking at its performance though, I would recommend a 5770 at its price! No need to wait for price drops, it is the same price now!!
Reactions: m3th0d
PC Evangelist
Also for SC2 CPU is much more important. a Core i7 + 9800GT will run it much better then your CPU + GTX480.
1 - 20 of 26 Posts
