1 - 6 of 6 Posts
Hi guys,
Hope you can help with this sooooo annoying problem I have with my 9800GTX OC card
I purchased it around 2 year ago so I cant take it back as the warranty has expired. So i was hoping one of you guys would know what the problem is. I have all latest drivers and the latest bios on my MB. I have attached a screen shot of my problem.
Thanks
Yes those are artifacts. I had very similar looking symptoms on my 8800 MGTX, and this was in the last couple of months. However i wasn't too bothered and i kept using it. My GPU failed on me eventually. I think it's high time for an update anyway
time to go card shopping
Is it at stock clocks?
Try lowering your OC if you have it bumped. I see its a factory OC, so maybe try to run it at reference clocks. Also heat may be an issue with it like Term stated.
Do you have MSI Afterburner or something to setup a custom fan profile on it?
1 - 6 of 6 Posts
