9800gt help
317 Views 5 Replies 3 Participants Last post by  vacs
got a gigabyte 9800gt 1gb and as i see there i no temp monitoring or fan control (it's too loud this way)...so i was wondering if it would make a diference if i flash it with a xfx or zotac bios? would i get this 2 options then?
i tryed searching for a improved gigabyte bios but couldn't find anything,not even the orginal bios for thid 1gb version...
1 - 6 of 6 Posts
First of all, in regards to fan control, are the wires going to the fans: 3 wires or 4 wires?
Edit:Or are they 2?
link to said card?
2 wires
2 wires = power only: 1 positive (red), and 1 negative (black)
This means it has no RPM (speed) sensing, or PWM (speed adjusting) capability.
Resistors will work, that is what I have used in the past in this situation, with a Xigmatek Battleaxe.
ok...thanks for the info...
what about the temp monitoring?
edit: i found the solution...i sold it
1 - 6 of 6 Posts
