Hi I just Overclocked my 9800 gt 1gb ddr3 the other day. While it was overclocked I got some wierd malfunctions in World at War. All the guns in the game turned green. There were also wierd smoke clouds that were flashing. So knowing that I just overclocked the graphics card i quickly turned off my computer. Now i was using a VF1000 which fits perfectly on the 9800gt with ram sincs. The fan though plugs into the motherboard (
MBN790IUL9) and i believe it was running at some stock speed and not adjusting. I installed the hardware fan controller and set the fan to around 80-90%. I returned the GPU to stock settings. I continued playing a little while later and everything was fine. the next day i was playing World at War and the game would run fine until i died. Then when the game would reload i would get these wierd flashing smoke clouds and what seemed like a tint/ contrast adjustment(the colors looked a little warmer). I thought they were software issues because They would appear after i died and the game reloaded. I was trying to watch some movies with my girlfriend and my dvd player was broken. She brought over her HD LCD 32" 1080p with built in dvd player. So naturally I had to hook it up to my computer to see how it looked . After I hooked it up and loaded World at War I got masive artifacts on the second level. They were small artifacts covering all the water and around edges of objects. Some objects would leave a ghosting type blur. Some characters seemed they were rendered perfectly and the frame rates seemeed to be ok..... I didnt check the exact frames. Now my computer displays artifacts in World at War. The only other game I have access to at this time is AoE III I turned the settings all the way up but i saw no artifacts, but the game seemed to choke up every ounce in a while. The game also seemed bland. I overclocked the card to 760/1100/1900. so my guess is i fried the pixel shader. whatever that is. I disasembled the card and i noticed there are these dots on the corners of the ram chips and some other chips. These dots semed to be some type of indicator. They are slighty different shades of black/grey with a different type of gloss. This one chip that is near the ram has yellow spots near what i believe to be the indicator and the circle is also a yellow color. The card does not display artifacts unless in an intense 3d rendered program. Also im using windows 7 This picture shows the chip that i believe to be fried. This is not my card just a pic i found online.
So my questions are. What does this chip do on the card? Do you think my Vram was damaged?
Most importantly can i return it to newegg even though it was overclocked? Has anyone had trouble returning products to newegg? If they can tell it was overclocked anyone know any good links to reset video bios.
