1 - 7 of 7 Posts
Hey guys I have a quick question.
When I had windows XP on my PC I was able to use the resolution 1600x900. Now that I have installed vista I can no longer use this resolution. My question is, is this because of nvidia drivers? If so does anyone have any idea on how to get this resolution back? My Monitor btw is a Samsung HDt220. Thanks in advance.
· Not new to Overclock.net
I apologize for this question, but did you install Vista drivers from NVIDIA, or are you still using the same ones you had in XP?
Do you know whether or not it's set to the monitor's Native Resolution?
No, native resolution has always been 1680x1050. I just likes using 1600x900 for gaming becuz it looks nicer. but now I don;t get the resolution at all and i get 1360x768.
Hmm. Are there drivers for that monitor that are supported in Vista? I don't know if this will help any, but it might.
And I'm surprised that I'm the only one replying. lol
· Premium Member
How does it look nicer? Near-native resolutions always look much blurrier than native res.
You should have a setting in your games called Anti-Aliasing. In every game but Crysis or FarCry 2 at 1680x1050 you should have no problem going up to 8xAA. Use it.
1 - 7 of 7 Posts
