9800GTX Windows 7 64bit How to check for artifacts
1285 Views 1 Reply 2 Participants Last post by  Anth0789
Hey folks. I used to use atitool to check for artifacts with that neat little cube thingy when i used Win XP.. Now that ive installed Win 7 64bit i cant get Atitool to work.. You know of any other program that is as easy to use and works with the OS?
Regards
1 - 2 of 2 Posts
Furmark is a good app to test for stability.
http://www.ozone3d.net/benchmarks/fur/
1 - 2 of 2 Posts
