1 - 8 of 8 Posts
hmmmmmmmmm i just got 4.50ghz after a few hours of Linx but my temps are very odd core 6 is showing 80c and the rest of the cores are in the 60s
what could this mean
as for the cpu temp itsself its 56c under full load
http://valid.canardpc.com/show_oc.php?id=1748266
any input will be helpful
Originally Posted by SecrtAgentMan;12987091
Have you tried other software to factor out a false reading from the program you're using?
Could just be a bad sensor if anything.
ya it could be it does not occur at 4.40 tho hmmmmmmmmmm ill try a differnt sofware and see
thanks for the input
Theres probably an air pocket in between you CPU and heatsink.
Reactions: III-Kill-ZonE-III
ill also try a reseat if the software does the same thing and see if keeps occuring ill report back it just started as soon as i went from 4.40 to 4.50 hmmmmmmm
thanks for your input
Originally Posted by mymlan;12987275
Make sure that you're using RealTemp. It's the most accurate temperature sensor I've found for i7's.
http://www.techpowerup.com/realtemp/
thanks for the link ill restart testing soon as i can
thanks for the link and the input
Discussion Starter · #8 ·
hmmmmmmmm all cores seem to be loading around the same for now ill report back if it does the same thing
core1 72c core2 71c core3 64c core4 68c core5 72c core6 72c load temps as of right now testing....
thanks for the link and thank you all for helping and your inputs
1 - 8 of 8 Posts
