1 - 17 of 17 Posts
running folding on my rig under name Lotik I have 94-100c under all cores 100% load for last 50+ hours.
Is it a normal temperature or should I be concerned :)
Thanks,
Asgaroth
CPUID HWMonitor Report
Binaries
HWMonitor version 1.4.1.0
Monitoring
Mainboard Model Z390 Taichi Ultimate (0x000006CD - 0x1709EDF2)
LPCIO
Hardware Monitors
Hardware monitor Nuvoton NCT6791
Voltage 0 1.23 Volts [0x4D] (CPU VCORE)
Voltage 1 5.02 Volts [0xD1] (+5V)
Voltage 2 3.46 Volts [0xD8] (AVCC)
Voltage 3 3.46 Volts [0xD8] (3VCC)
Voltage 4 11.90 Volts [0x7C] (+12V)
Voltage 5 1.06 Volts [0x84] (CPU PLL2)
Voltage 6 1.06 Volts [0x84] (PCH +1.0V)
Voltage 9 2.56 Volts [0xA0] (DRAM VPP)
Voltage 13 1.36 Volts [0xAA] (DRAM)
Voltage 14 1.22 Volts [0x98] (VCCIO)
Temperature 0 50 degC (122 degF) [0x32] (Mainboard)
Temperature 1 94 degC (201 degF) [0xBC] (CPU)
Fan 0 0 RPM [0x0] (Chassis #3)
Fan 1 1588 RPM [0x634] (CPU #1)
Fan 2 1210 RPM [0x4BA] (CPU #2)
Fan 3 0 RPM [0x0] (Chassis #1)
Fan 4 0 RPM [0x0] (Chassis #2)
Fan 5 0 RPM [0x0] (Chassis #4)
Hardware monitor Nuvoton NCT6793
Voltage 9 1.04 Volts [0x82] (Cold Bug Killer Voltage)
Voltage 11 0.94 Volts [0x75] (DMI)
Fan 0 1180 RPM [0x49C] (Chassis #5)
Fan 1 0 RPM [0x0] (Chassis #6)
Hardware registers
Hardware monitor D3D
Hardware monitor NVIDIA NVAPI
Voltage 0 1.03 Volts [0x407] (GPU)
Power 0 95.35 pc (GPU)
Temperature 0 77 degC (170 degF) [0x4D] (GPU)
Fan 0 2088 RPM [0x828] (GPU #0)
Fan PWM 0 59 pc [0x3B] (FANPWMIN0)
Clock Speed 0 1898.00 MHz [0x76A] (Graphics)
Clock Speed 1 3802.49 MHz [0xEDA] (Memory)
Clock Speed 2 n.a. (Processor)
Processors
Number of sockets 1
Number of threads 16
Timers
ACPI timer 3.580 MHz
Perf timer 10.000 MHz
Sys timer 1.000 KHz
Processors Information
Socket 1 ID = 0
Number of cores 8 (max 8)
Number of threads 16 (max 16)
Manufacturer GenuineIntel
Name Intel Core i9 9900K
Codename Coffee Lake
Specification Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
Package (platform ID) Socket 1151 LGA (0x1)
CPUID 6.E.C
Extended CPUID 6.9E
Core Stepping P0
Technology 14 nm
TDP Limit 95.0 Watts
Tjmax 115.0 °C
Core Speed 4700.0 MHz
Multiplier x Bus Speed 47.0 x 100.0 MHz
Base frequency (cores) 100.0 MHz
Base frequency (ext.) 100.0 MHz
Stock frequency 3600 MHz
Max frequency 5000 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX, AVX2, FMA3, TSX
Microcode Revision 0xAE
L1 Data cache 8 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 8 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 8 x 256 KBytes, 4-way set associative, 64-byte line size
L3 cache 16 MBytes, 16-way set associative, 64-byte line size
Max CPUID level 00000016h
Max CPUID ext. level 80000008h
Cache descriptor Level 1, D, 32 KB, 2 thread(s)
Cache descriptor Level 1, I, 32 KB, 2 thread(s)
Cache descriptor Level 2, U, 256 KB, 2 thread(s)
Cache descriptor Level 3, U, 16 MB, 16 thread(s)
FID/VID Control yes
Turbo Mode supported, enabled
Max non-turbo ratio 36x
Max turbo ratio 50x
Max efficiency ratio 8x
O/C bins unlimited
Ratio 1 core 50x
Ratio 2 cores 50x
Ratio 3 cores 49x
Ratio 4 cores 48x
Ratio 5 cores 48x
Ratio 6 cores 47x
Ratio 7 cores 47x
Ratio 8 cores 47x
IA Voltage Mode PCU adaptive
IA Voltage Offset 0 mV
GT Voltage Mode PCU adaptive
GT Voltage Offset 0 mV
LLC/Ring Voltage Mode PCU adaptive
LLC/Ring Voltage Offset 0 mV
Agent Voltage Mode PCU adaptive
Agent Voltage Offset 0 mV
TDP Level 95.0 W @ 36x
Temperature 0 93 degC (199 degF) (Package)
Temperature 1 85 degC (185 degF) (Core #0)
Temperature 2 86 degC (186 degF) (Core #1)
Temperature 3 94 degC (201 degF) (Core #2)
Temperature 4 93 degC (199 degF) (Core #3)
Temperature 5 91 degC (195 degF) (Core #4)
Temperature 6 93 degC (199 degF) (Core #5)
Temperature 7 88 degC (190 degF) (Core #6)
Temperature 8 88 degC (190 degF) (Core #7)
Voltage 0 +0.00 Volts (IA Offset)
Voltage 1 +0.00 Volts (GT Offset)
Voltage 2 +0.00 Volts (LLC/Ring Offset)
Voltage 3 +0.00 Volts (System Agent Offset)
Voltage 4 1.23 Volts (VID #0)
Voltage 5 1.22 Volts (VID #1)
Voltage 6 1.20 Volts (VID #2)
Voltage 7 1.25 Volts (VID #3)
Voltage 8 1.22 Volts (VID #4)
Voltage 9 1.22 Volts (VID #5)
Voltage 10 1.22 Volts (VID #6)
Voltage 11 1.23 Volts (VID #7)
Power 00 162.96 W (Package)
Power 01 160.29 W (IA Cores)
Power 02 n.a. (GT)
Power 03 2.67 W (Uncore)
Power 04 4.26 W (DRAM)
Clock Speed 0 4700.00 MHz (Core #0)
Clock Speed 1 4700.00 MHz (Core #1)
Clock Speed 2 4700.00 MHz (Core #2)
Clock Speed 3 4700.00 MHz (Core #3)
Clock Speed 4 4700.00 MHz (Core #4)
Clock Speed 5 4700.00 MHz (Core #5)
Clock Speed 6 4700.00 MHz (Core #6)
Clock Speed 7 4700.00 MHz (Core #7)
Core 0 max ratio 50.0 (effective 47.0)
Core 1 max ratio 50.0 (effective 47.0)
Core 2 max ratio 50.0 (effective 48.0)
Core 3 max ratio 50.0 (effective 47.0)
Core 4 max ratio 50.0 (effective 48.0)
Core 5 max ratio 50.0 (effective 47.0)
Core 6 max ratio 50.0 (effective 47.0)
Core 7 max ratio 50.0 (effective 48.0)
Display Adapters
Display adapter 0
ID 0x1090304
Name NVIDIA GeForce GTX 1070
Board Manufacturer ASUSTeK Computer Inc.
Revision A1
Codename GP104
Core family 0x134 (GP104)
Technology 16 nm
Memory size 8 GB
Memory type GDDR5
Memory vendor Micron
PCI device bus 1 (0x1), device 0 (0x0), function 0 (0x0)
Vendor ID 0x10DE (0x1043)
Model ID 0x1B81 (0x85A0)
Revision ID 0xA1
Performance Level 0
Core clock 1898.0 MHz
Memory clock 3802.5 MHz
9 Cans of Ravioli
not sure what the huge wall of text is supposed to do, all the information we really needed is what cooler you're using, what OC (if you are OCed) and at what voltage, and what your ambient temp is lol.
if you're leaving voltage on auto then you're likely shoving ~1.3v into it and on anything but a custom loop a 9900K at 1.3v is going to run hot. my Taichi on the launch BIOS was pushing ~1.4v into my 9900K and it's fine with ~1.17v at stock.
Graphics Junkie
Damn what a mess of a post.
No of course it's not normal. That's the temp at which your CPU will start to throttle down so sounds like you have a major cooling issues. Make sure you're heatsink is installed correctly.
Discussion Starter #4
Sorry guys, cleaned log from CPUID monitor.
If that Hardware monitor is correct your cpu vcore is pushing 1.5v that’s really high.
9 Cans of Ravioli
it's not. a lot of Z390 boards don't have an accurate vCore sensor and you're supposed to go off VR OUT. on my Taichi CPU-Z and the vCore sensor in HWInfo reads ~1.38v when I'm really only ~1.25v.
OP; use HWInfo and go off the VR VOUT sensor, that's the vCore your CPU is actually getting. if you're stock you don't need more than 1.25v at the most, likely will be fine with 1.15v.
also if you're on any BIOS older than 1.8 then update, the older BIOSes are way too aggressive with LLC.
Discussion Starter #7
Cooler = Noctua NH-U14S
Bios P4.10
Graphics Junkie
OP what are your temps at stock?
9900k hitting those temps is normal.
You should try for lower but yeah that’s normal for these chips.
Avid Memer
With an NH-U14S? Definitely not normal. Either too much power or poor contact with the IHS. Only way it's normal is if your ambient temperature is in the 30's or 40's.
Discussion Starter #12 (Edited)
Yes, ambient around 38-45 after pausing folding for 10 min
Ambient temperature is measured with a room thermometer near your computer.
I would remove your cpu cooler. Clean BOTH the top of the cpu and the bottom of you cooler well with 91% or higher Isoprophyl alcohol and reapply quality thermal paste. I use Noctua.
Reassemble and then check your temperatures.
Discussion Starter #15
Ambient means your room temperature I think
Ohh, now I know. TY. Ambient room temperature about 70F.
Running folding on Medium brought the temperature down to 85c
Discussion Starter #17
Just an update adding a second cooler and rotating the airflow 180d brought full load temperature to 75c full load.
2459261
2459262
1 - 17 of 17 Posts
