Well, here I go again.
I traded the VW 411 for a 1999 BMW Z3 2.8 roadster, with the intention of getting it to proper show condition. While the VW was certainly a great show car, I just like the Z3 much more, and felt now was the time to change.
To do list (to be updated):
- Fix dings, chips and scratches - To be done later, will likely get a full respray.
- Find and install passsenger seat motors
- Fix the radio screen - Common fault, should be a bad connection on the screen ribbon.
- Fix the CD shuttle - Need to get a new CD drive motor. It kind of works, so it's rather low priority.
- Fix gap between driver door window and ragtop - Will need soft top replacement, one corner was trimmed too short.
- Window regulators
- Some minor odds and ends in the interior
- Refinish a set of engine covers
- Rear shocks
- Rear brake pads
