What project should OCN choose for Swimming?
1 - 20 of 37 Posts
Swimming project is [email protected] If you can get them, BHDB give much better credit than BHSpin. Also have to watch out for BHSpin tasks that run for hours and hours longer than normal for no credit. The tasks are all around the same length, so abort anything that runs abnormally long. It's just a bad task.
The 2nd project of the BOINC Pentathlon in the discipline Swimming is:
[email protected] (https://universeathome.pl/universe/)
All credits granted between
05 May 2018, 0.00 (UTC) and
12 May 2018, 0.00 (UTC) will be taken into the BOINC Pentathlon validation. Please note that pending credits cannot be taken into account! The statistics for this project can be found at
http://www.seti-germany.de/boinc_pentathlon/statistiken/challenge.php?challengeid=2&lang=en
For reference on my 1950x, the BHDB tasks ran at less than half the time of BHSpin for the same 666.67 credit. So I would select BHDB app and the extra checkbox about sending task from other apps if there is no work.
Edit: There is a task limit here as well. I think it was 256 on my 32 thread machines. Not sure if that was 8 per thread or 256 per host.
⤷ αC
Guess I'm going to start off swimming. :p
I need 2 more RAM sticks and maybe I'll be able to push 40 threads
Just a Crazy Cat in a Box
Preloaded up 120 tasks on the 1900X in a separate boinc client.
Hmmm, I give a good guess that there is a way to shoot a terminal command to start or stop a project in the boincmgr?
I will be away for the weekend for a short bit. Would like to setup a script to fire off to drop all the NumberField units out then turn on to crunching the Universe units.
https://boinc.berkeley.edu/wiki/Boinccmd_tool
⤷ αC
It's weird because I can access the website, I didn't have hosts file blocked.
edit: I rebooted the VM and it seems that cleared it up for that one
edit2: to fully rectify this I had to add <http_1_0>1</http_1_0> to the options of the cc_config.xml
1 - 20 of 37 Posts
