You will find that most people opt for the push method over the pull method or use both.
IMO nothing wrong with that fan 110cfm is more than enough to cool the HS.
Originally Posted by thegreatsquare ![]() I apologize ahead of time for being a PITA. I've been told I picked out the wrong fan for my Megahalem twice. The last "wrong fan" I got was the Scythe Kaze Jyuni 1900RPM [110cfm]. I've been told that it is not good for HSF in a few posts. I just came across where the Kaze Jyuni got into my head. It was used on the PCper review of the Megahalem. Pics below. I also noticed that this fan was set up as a "pull" and not a "push" fan. Seems the test was without a push fan. So I guess I should set the fan to pull if I just use one, huh? [My last and first HSF was the ASUS Silent Square so this issue didn't come up for me before.] Why is this fan no good? Is it a matter of work life or something? If this is the case I only use my desktop for gaming and will only be on for ~25hrs a week max and probably 10-15hrs a week. It is shut down when I'm done. No sleep. No hibernate. With that in consideration, is the Scythe Kaze Jyuni 1900RPM [110cfm] still really a bad fan for my Megahalem? |
Originally Posted by Blackhawk4 ![]() ...but the lower static pressure could be a problem when overclocking as high as you can get. |
