1 - 14 of 14 Posts
Hi, im looking for a big case that is around the price of £40-£50 and looks nice aswell!<br><br>
Thanks for your time!<img alt="" class="inlineimg" src="/images/smilies/biggrin.gif" style="border:0px solid;" title="Big Grin">
Big=Full tower?
maybe if you turn those pounds £ into dollars $ we can search better for ya <img alt="" class="inlineimg" src="/images/smilies/wink.gif" style="border:0px solid;" title="Wink">
Discussion Starter #4
I live in the UK not the US but if there si a good one in the US then can i have a look? And yes a full tower
<div>Originally Posted by <strong>Blowie</strong></div>
<div style="font-style:italic;">maybe if you turn those pounds £ into dollars $ we can search better for ya <img alt="" class="inlineimg" src="/images/smilies/wink.gif" style="border:0px solid;" title="Wink"></div>
</td>
</tr></table></div>
Try websites such as <a href="http://www.overclockers.co.uk" target="_blank">www.overclockers.co.uk</a> <a href="http://www.xcase.co.uk" target="_blank">www.xcase.co.uk</a> <a href="http://www.ebuyer.co.uk" target="_blank">www.ebuyer.co.uk</a> <a href="http://www.scan.co.uk" target="_blank">www.scan.co.uk</a> and also <a href="http://rover.ebay.com/rover/1/711-53200-19255-0/1?campid=5337413396&toolid=10001&mpre=http%3A%2F%2Fwww.ebay.co.uk%2F" target="_blank">www.ebay.co.uk</a> for a start
Discussion Starter #7
i looked at them, i just thort some of you guys could recommend a good big case
what dimensions are full towers??<br><br>
i dunno if mine is or not. <img alt="" class="inlineimg" src="/images/smilies/tongue.gif" style="border:0px solid;" title="Stick out tounge caps">
not necessarily a full tower, just a mid-tower with space, like these ones (using sites to show pictures only)<br><br>
Thermaltake Soprano - <a href="http://www.newegg.com/Product/Product.asp?Item=N82E16811133145" target="_blank">Case</a><br><br>
will suggest more soon
Filthy Casual
Well a Lian Li PC-7B would fit your needs likely, it is a well built, spacious Mid Tower, which retails for $90 USD. Also, a Sunbeam Transformer case is the cheapest full tower available currently. Just check the sites that Niko-Time posted and see if you can find either of those cases. You woun't be disappointed.
A Chenming Full Server case can be had for way under your budget and has soo much room. You wont know what do with it all!<br />
<br />
pink
<tr>
<div>
Originally Posted by <strong>Mr Pink57</strong>
</div>
<div style="font-style:italic">A Chenming Full Server case can be had for way under your budget and has soo much room. You wont know what do with it all!<br />
<br />
pink</div>
</td>
</tr>
</table>
</div>I couldn't agree more<br />
<br />
<a href="http://www.newegg.com/Product/Product.asp?Item=N82E16811125480" target="_blank">http://www.newegg.com/Product/Produc...82E16811125480</a><br />
I personally own these Chenming cases for render nodes. I was amazed at how cool these cases stay. With the rear 120mm exhaust fan included and with 2x 80mm fans for the HD cages the case is brilliant. And the Air duct for the cpu work awesome.<br />
<br />
They also sell one with a side window but it uses 2x 80mm fans for exhaust instead of the type in the link above. I like side windows only for watercooled PC's. Those side vents really really help out for overclocking a PC on strictly air.<br />
<a href="http://www.newegg.com/Product/Product.asp?Item=N82E16811125475" target="_blank">http://www.newegg.com/Product/Produc...82E16811125475</a><br />
<br />
<br />
both these cases are excellent at just above the 50 dollar mark
<a href="http://www.overclock.co.uk/product.php?productid=16341&cat=0&view=rel" target="_blank">http://www.overclock.co.uk/product.p...cat=0&view=rel</a><br><br>
Here is a full server version in the UK. However I dont know of many other shops in the UK so you can look around for the color you may want. They also have a smaller verison which is still pretty large in a variety of colors.<br><br>
pink
<div>Originally Posted by <strong>Mr Pink57</strong></div>
<div style="font-style:italic;"><a href="http://www.overclock.co.uk/product.php?productid=16341&cat=0&view=rel" target="_blank">http://www.overclock.co.uk/product.p...cat=0&view=rel</a><br><br>
pink</div>
</td>
</tr></table></div>
omg that thing is huger than huge.. you could charge rent with the space your gona have left over!
1 - 14 of 14 Posts
