I have a pump/res combo they are great in the way that they are nice and compact, you can even get them for drive bays, however they are quite ugly, something like an EK or FrozenQ cylinder with say a koolance pump top is much nicer looking. It all depends on what you are going for. - Im refering to a Laing D5 as the pump.
Depends on the fans you are useing and the target RPM ie. how loud or quiet do you want it... If you want a quiet rig then go for Low RMP fans and get a RAD with a low fin count such as a RX360. On the other hand if you dont care you can blast the Black ice with 1200+ RPM fans and get a better result.
Thats overkill mate. An 850 Watt will be ok for sli. But if you are SLIing then you will need more rad.
