I'm not entirely sure if you can do it simply clone that, 2 TB is HUGE, so you must have a lot of stuff. I recently RAID'd two 500gigs from a 750 HDD and RAID'd them together, then used an external HDD enclosure to have my original hard drive seen and I copied it over.
OR attach it as part of the non-raided volume SATA port if you have more than 2 and set to boot off of the RAID volume, then the xfer rates are pretty quick.
But that doesn't really answer your question. I know it was a pain in the ass setting up the RAID on mine, but I had cable issues.
