1 - 8 of 8 Posts
well its been a week now and i had my pentium d 940 3.2 ghz at a good looking 3.83 with air cooling and my boss was telling me it wont make a good diffrence with out a good cpu burn in i need ideas or programs thanks for u help
prime95<br />
<a href="http://files.extremeoverclocking.com/file.php?f=103" target="_blank">http://files.extremeoverclocking.com/file.php?f=103</a>
so what would this program do
running two of them at the same time would put your processor on full load, hence high heat output=burn in. It is a test commonly used to prove stability in OC'ing.
just select the torture test option<br />
<br />
click small ffts<br />
<br />
if it dosent have an error for 6 hrs your good<br />
<br />
its stable<br />
<br />
Oh BTW you have to run the program twice at the same time if you have a dual core<br />
<br />
<br />
<br />
EDIT:<br />
<br />
if someone told you that the overclock would not make a difference till you ran this program thats BS<br />
<br />
it is effective immediatley<br />
<br />
to test the improvement download super pi and check
Filthy Casual
or you could try CPU burn in...
Reactions: Oknilp
how do you run two? the second closes right away :S
<tr>
<div>
Originally Posted by <strong>1c0n</strong>
</div>
<div style="font-style:italic">how do you run two? the second closes right away :S</div>
</td>
</tr>
</table>
</div>put one in MyDocuments, then create a folder name Prime95(or EIWOE) and save another copy of hte .exe file in there. now you can open them both up at the same time.
1 - 8 of 8 Posts
