Greetings,
After 6 hours of searching the internet I registered here to seek proffesional help. At first, I would like to say that I'm a new to overlcocking. So please, don't be hard on me. I have some FPS problems with my gtx295.
This is my system:
Intel core i7 920 2,67GHz
P6T deluxe v2
4x 2gb ddr3 memory
Intel SSD X25-M V2 160GB
Club3d GTX295
syncmaster 2494hm monitor(24 inch)
win 7 ultimate 64 bit
What is exactly my problem?
I find my FPS too low for my system. I've been testing it in several games like WoW, crysis and far cry 2. I've been using benchmark tools in the last two games and my fps was allways lower than other similiar tests with non-overclocked systems on the internet. For example: While I had 50-60 fps they had around 80 fps with farcry 2. I've used the exact same graphic settings. When I tested crysis (very high, no AA) with a benchmark tool I got around 30 FPS while I should get 50 or more non-overclocked - according to other tests.
Friends on WoW with a worse system than me and all settings max got their fps at 60 all the time while I get around 30-40.
What have I tried?
I reinstalled all drivers, got the latest for every component of my computer
I changed the Nvidia 3d settings but nothing changed
I started to overclock my CPU a bit to 2,9 GHz and I had no performance improvements so I put it back to default.
I tried diffrent resolutions, I ran tests with 1680-1050 and 1920-1200 resolutions. But both gave way less FPS then internet tests showed.
I also ran performancetest and here are the results
GPU-Z and CPU-Z
I'm hopelessly lost in what to do. I just bought this new set and I just want it to run good. I hope anyone could see the problem. And again, I'm pretty new at this so post if I need to add some information. I can post crysis and farcry 2 tests results if necessary.
I really hope to get this fixed, thanks in advance
