1 - 6 of 6 Posts
Apologies if this is considered too rude but it is after all only a joke...
remember... Humor...
Last year I upgraded Girlfriend 1.0 to Wife 1.0 and noticed that the new program began unexpected child processing that took up a lot of space and valuable resources. No mention of this phenomenon was included in the product brochure.
In addition, Wife 1.0 installs itself into all other programs and launches during system initialization where it monitors all other system activity. Applications such as Poker Night 10.3 and Beer Bash 2.5 no longer run, crashing the system whenever selected.
I cannot seem to purge Wife 1.0 from my system. I am thinking about going back to Girlfriend 1.0 but un-install does not work on this program. Can you help me?
Dear Wife 1.0 user,
This is a very common problem that men complain about but is mostly due to the following primary misconception: Many people upgrade from Girlfriend 1.0 to Wife 1.0 with the idea that Wife 1.0 is merely a "Utilities & Entertainment" program.
Wife 1.0 is an Operating System and is designed by its creator to run everything.
Warning! Do not try to un-install, delete, or purge the program from the system once installed. Trying to un-install Wife 1.0 can be disastrous. Doing so may destroy your hard and/or floppy drive. Trying to un-install or remove Wife 1.0 will destroy valuable system resources.
You cannot go back to Girlfriend 1.0, because Wife 1.0 is not designed to do this. Some have tried to install Girlfriend 2.0 or Wife 2.0 but end up with more problems than the original system. Look in your manual under 'Warnings-Alimony/Child Support.'
Others have tried to run Girlfriend 1.0 in the background, while Wife 1.0 is running. Eventually Wife 1.0 detects Girlfriend 1.0 and a system conflict occurs; this can lead to a non-recoverable system crash.
Some users have tried to download similar products such as Fling and 1NiteStand. Often their systems have become infected with a virus. I recommend you keep Wife 1.0 and just deal with the situation.
Having already installed Wife 1.0 myself, I might also suggest you read the entire section regarding General Protection Faults (GPFs). You must assume all responsibility for faults and problems that might occur. The best course of action will be to push the 'Apologize' button then reset button as soon as lock-up occurs. The system will run smooth as long as you take the blame for all GPFs.
Wife 1.0 is a great program but is also a very high maintenance program. Suggestions for improved operation of Wife 1.0: Monthly, use utilities such as TLC and FTD. Frequently use Communicator 5.0 Tech Support.
Stale joke is stale
1 - 6 of 6 Posts
