I am using abit OC Guru to oc my comp
EXT/AGP/ PCI CPU FREQ Cpu Ratio
Heres the set up 220/66 / 33 2423.2MHz 11X
V Core 1.65 AGPV 1.55 DDRV 2.7 nbv 1.6 SBV 2.6 HTV 1.3
This is verifyed With CPUZ
The programs I am running to check the oc stability is
CPU Z
ABIT EQ To check the temps
XP KEY GEN
The Cpu temp is 33 C
The Sys is 30.C
And the PWM is running at 50C
Everything runs fine the Key gen is running about 70 keys in 10 min
CpuZ is constantly updating cpu clock
And Abit EQ works but then locks up
every thing else works fine
Do I have to many programs open and running or is the oc to much or do you think this is an unstable oc
CPU Z
XP KEY GEN
The Sys is 30.C
