For passive cooling I'd probably go with the Thermalright IFX-14. Due to its massive size, it handles being passively cooled pretty well.
Originally Posted by sLowEnd ![]() However, if you want silence, you would be better off using a low speed fan like this http://www.scan.co.uk/Products/120mm...1D-Fan-800-RPM instead of going truly passive. |
Originally Posted by sLowEnd ![]() If you can fit a Xigmatek Achilles in your case right now, I don't see why the Baram wouldn't fit. |
Originally Posted by meticadpa ![]() For passive cooling I'd probably go with the Thermalright IFX-14. Due to its massive size, it handles being passively cooled pretty well. |
Originally Posted by imadude10 ![]() I agree with this. Even with a tiny amount of air moving, the cooling gained is much better. 33CFM and ~9dba. I don't think you will hear it. ![]() |
