1 - 6 of 6 Posts
Administrator
well you c wot i mean is dat i get sum graphics corruption with some games which i never used 2 get and i think it may be my directx ....oh and btw if sum 1 could plz point me in the direction of a direct x 9 -9c uninstaller that would be great
reps for ppl who help
Uninstall DirectX with this program. Make sure that before you run it, you have DirectX9.0b on a CD (if you have a game that has it on the game disk!) so that when you boot up in safe mode, you can install it. It seems that 9.0b is very difficult to find. Or you can try directX9.0c Again. I would suggest that you uninstall "c", then install "b" and make sure that everything is working. Then update to "c" again. You could have a GPU driver problem (which sounds much more likely).......
1 - 6 of 6 Posts
