but do you have good control over ur mouse if you are playing fps and what made you go shidenkai and not shiden
Shiden-kai gives you no control whatsoever (mine is the XSOFT version). - - - edit: I think it is just with Savu, which has some of the smoothest mouse feet - Control on this pad is OK with EC2 and Imperator
dust on hayate would affect ur mouse movement?
Considering how an optical sensor works, no. That is if the dust does not dislodge and stick to the lens.
I try to keep my Hayate clean but dust doesn't seem to affect tracking in my experience. The pad itself seems to be picky with the sensors used on it when it comes to tracking. The G9X worked very well with it. The Naos 3200 didn't and my current Deathadder 2013 tracks seems ok with it. I think Artisan has a compatibility chart on their website but its very incomplete so its not really useful.
my ikari laser seems to track very well with the hayateOriginally Posted by jologskyblues
