1 - 2 of 2 Posts
Hey fellas im looking to buy a water cooling kit for my AMD atholon XP socket A and i was wondering if this would work ....and is this a good kit i know it dont have fans so i was kinda wondering if its any good at cooling??
It kinda looks like 1 fits all kinda deal but i wona make shure so i dont drop the cash on the rong deal thanks..
Zalman Reserator 1
Socket 462 478 754 940 P4 Athlon XP MP 64 FX Opteron
http://cgi.ebay.com/Zalman-Reserator...QQcmdZViewItem
And this is a second one would this one be better than the one above and would it work also?
http://cgi.ebay.com/Gigabyte-3D-Gala...QQcmdZViewItem
and last one
http://cgi.ebay.com/Thermaltake-BigW...QQcmdZViewItem
Hey Allen,
I'm not an expert, but, going from reviews, here's my free opinion.
Being external, the Reserator is about as easy to install as WC comes, and completely silent, but only adequate in cooling--fine for stock speeds in moderate ambient temps only. cnet recommends its for first time users. Early users had pump problems--I don't know if this has been cured in newer units. Get it if you value silence and easy install over all else.
Gigabyte--easy install, pump a bit noisy and bulky, surprisingly good performance for an entry level kit--maybe a degree or two C better than BigWater. At least one member here recommends it.
BigWater -- quiet, compact, easy to install, surprisingly good performance for an entry-level kit. I bought the SE, and will review it once I've checked it out.
I hope this helps, and have fun!
1 - 2 of 2 Posts
