1 - 3 of 3 Posts
I am buying this mother board.
EVGA E758-A1
http://www.newegg.com/Product/Produc...82E16813188039
and this RAM
CORSAIR DOMINATOR 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600
http://www.newegg.com/Product/Produc...82E16820145224
The mother board supports 1600+ mhz and the ram as well.
My question is, to run triple channel, do I have to reset the timing and speed once I install the ram, or will this mother board automatically time the ram to 1600 mhz as soon as I plug it in? I know I match the colors for triple channel.
If the timing needs to be set, could anyone tell me what it should be?
Thank you ahead of time.
You probably have to setup your timings and voltage also speed.
1 - 3 of 3 Posts
