a wireless card with external antenna?
354 6
so ive been looking for a laptop wireless card (prefer g) with a wireless antenna connection, because ive been wanting to toy with long range wireless and i cant seem to find a card anywhere.
1 - 7 of 7 Posts
· AS 396507
what exactly are you trying to accomplish? bigger poles doesn't necessarily increase range.
im just wanting to experiment with wifi antennas and out door ranges, not really trying to accomplish anything imparticular here.
im wanting to really play with cantennas but that dish also looks interesting
· AS 396507
i use this
http://www.data-alliance.net/servlet...802.11n/Detail
which is a good deal, i paid 70.
and this
http://www.l-com.com/item.aspx?id=22271&cmp=ALSOS
with the RP-SMA male connection
just make sure you learn how the connection terminals work so you order the right stuff
for instance, with the RP (reverse polarity) plugs, the threaded, convex connector is the "female" one, and the and the concave connection is the male... with RP it flips and that confused me for like a week...
edit: i encourage you to utilize l-com (formerly hyperlink technologies). they're quite reputable.
· Premium Member
just buy an antenna.
1 - 7 of 7 Posts
