Geting spikes in bf4 that is crazy. I´m using a dgpu (r9 270x) so it cant be because of the r7 in the chip i think. Tha cpu is overclocked to 4.4ghz wih voltage set to 1.5 and it dont get hotter than 45c (under water) so it shouldnt be the temps either. I have made a test using prime95 for 1 hour with no errors so i dont realy understand the huge spikes, and when i get the spikes the game like pauses or something or a split seccond (even in 16 player maps). The fps shows 45-165 so thats kinda weird to. Im using te lattest driver from amd with mantle enabled in the game. The reason i use manle is that i dont have to use v-sync and therefore get a higher fps, with v-sync enabled i get lower than with dx11 though. Anyone got a solution for this?
Thanks in advance.
Thanks in advance.
