1 - 6 of 6 Posts
Is it worth updating? I'm currently using Revision 1009
Overclockiit
I would update it, but thats just me <img alt="" class="inlineimg" src="/images/smilies/rolleyes.gif" style="border:0px solid;" title="Roll Eyes (Sarcastic)">
well if you do you can allways revert back to your old bios if you dont like it, i would recommend it though they usually dont change something in the bios becasue theres nothign wrong if you know what i mean
Discussion Starter #4
Revision 1011 is a Beta on the Asus website though, bit risky using a Beta
Discussion Starter #5
Updated to Revision 1032 Beta, seems totally the same as 1009 to be honest don't notice any difference.
i used 1011 the entire i had my premium and it worked fine
1 - 6 of 6 Posts
