Difficult to say... you have 3 PCI slots you'll need 2 unobstructed slots... just remember to have OB sound disabled in the BIOS!
Originally Posted by markuk3 I have the A8Nsli deluxe with TV TUNE CARD AND MY XFI CARD with plenty of room to fit a second 7800gt with full h/s |
Originally Posted by ncsa The A8N is a different layout, has 3 PCI slots outside of the PCIe group - 2 of which would be free if SLi dual slot GPUs are used. He is asking about the A8N32... |
Originally Posted by Robilar Do you have the board in hand? The board will take 3 pci cards inbetween two SLI PCI-E video cards (2 in between and one below) as long as the cards are single slot cooling. For example, my 7800GT's have zalman vf-700's on them thus taking two slots. All I have free is one PCI (which I use for SB audigy 2 zs). If you actually look at the board, you will see that it won't be an issue. I was intially concerned about layout for my setup when I bought the board but it really comes down to what kind of cooling your cards have. I don't have a gtx but I assume most models use a single height cooling solution.If they are dual slot you are out of luck. Incidently, Tom's Hardware, Anandtech and HardOCP all rate this board tops for OC purposes. Not sure what you meant by this. Sorry if I misunderstood. " width is to i/o covers (each) cards themeselves are only half this wide,) " Only Asus and MSI have dual 16X on the market right now. |
