AAA! Unpinnable from jumplist!
517 Views 0 Replies 1 Participant Last post by  xd_1771
I think this might be related to a recent driver reinstall...
When I try to unpin, it "re-pins" itself and turns orange as if it was just pinned. When I try to move it, it duplicates; though I can clear that duplicated one, I just can't clear the original one! Plus, the link doesn't even lead to the nVidia Control Panel, when I click it it just says "Do you want to remove this icon." I click yes, the same thing happens. I re-pinned the nVidia Control Panel (the one above it, with the icon) though and that one works fine...
Any way to solve this?
I read that the same thing happens for network drives, and to solve this you have to right click the start menu > properties > uncheck "Store and display recently opened programs in the Start menu and the taskbar" > unpin program - this doesn't work either!
Help!?
EDIT: Stopping/restarting explorer.exe doesn't work either!!!
Well I solved it, but now I have to pin all my control panel items again
1 - 1 of 1 Posts
1 - 1 of 1 Posts
