I just got this mobo and tried to overclock my Pentium D 920 2.8ghz CPU. First couple of days I had running at 3.4ghz but it restarts the computer randomly when I play games. So I thought it wasn't stable on the overclocking. But I tried to set to default setting, it does the samething. And on the mobo i have SLI chip enabled but it is showing SLI ready not detected. I was wondering if is problem with the mobo.
I raised from 1.2 default to 1.3v is that enough? but its still doing it the restarting thing. because I don't have a NB fan i don't know if its going to be overheated.
O and do you know why when I set my memory timing to 3-3-3-9-12 it won't start up after I save and exit the bios. And the SLi ready not detected even I have the chip select on the arrow pointing the Sli side.
__________________________________________________ _________________________________
I checked the SLi the green light on the mobo is on, but its saying not detected in bios. Is something wrong with the bios that i need to update the bios or the switch card is broken?
thx alot for the info, I have my running at 3.5ghz right now, since I don't have NB fan heheh. And When ur saying the SLI part, I have 2x7800 GTX tho. I can enable SLI mode with nVidia control panel. not in bios.
I see your CPU temp is at 55c. on my abit EQ the warning temp is at 80 for CPU, whats the temp max can go up to without having damaging/overheating.
My temp is currently at 60 running othos test, voltage at 1.36 Cpu VTT voltage default, DDR2 voltage 1.95(somehow if i go up pass 1.95 it won't start the PC). NB 1.28voltage ( i'm using the zalman CPU cooling, i can't stick a fan on top of the heatsink, not enough room.
Overclock.net
