1 - 20 of 22 Posts
Folding computer, already have case and a GTX 295
. So tell me, YA or NAY
PSU is so large becuase i do plan on adding a 480 and another card down the road, so a total of 3 very power sucking cards, maybe a 460 or something?
Originally Posted by BizzareRide;11978072
Hello from Texas!
I say yay! Especially for the over kill power supply! Do you plan to get another 295 later on?
Plan on adding my current 480(whenever i upgrade) and possibleyanother something something soon down the road.
Ayyy from Tejas!!!
at first i couldnt understand why you chose a 1,000 watt psu...
then i saw the video card. lol.
Not only are you helping find a cure, youre also donating to the local utility company
Discussion Starter · #6 ·
Dont forget the economy either, doin my part! (as a kid)
Discussion Starter · #8 ·
Originally Posted by AMD SLI guru;11978492
yo from austin!
if you consider the 480, then you should look at GTX570. it's a little bit easier on wattage that the GTX 480
I already have the 480 though
. Its only when i upgrade im going to keep my 480 and put it in there
a rosewill PSU aren't those bad? might just blow up go with a quality psu like corsair seasonic or something along the lines of that
Discussion Starter · #12 ·
Originally Posted by LuckySe7ens;11978984
doesnt it seem like $55 is a lot of money for a 7200rpm 160gb mechanical HDD these days?
Heres one Bigger and cheaper and shipped free
Shoot i Paid a few dollars less then that 160GB for a 1TB F3
This Tuniq Ripper 1000w for $69 after rebate is one of our rated top PSU's at this wattage
Amazing! Thank you so much for saving me like 140$. Thank gosh im pulling the trigger tomorow night, still should of done more research on the PSU's as i have no knowledge about those. I was gonna get a 160$ antec PSU then you came along!
Discussion Starter · #14 ·
Originally Posted by zelix
honestly doubt rosewill is a good choice for a dedicated folding rig, something corsair or similar should be chosen.
Getting th Tuniq ripper 1k watt. Scored higher on OCN's PSU chart
Happy to help my friend.
Admittedly I'm no PSU guru either but luckily we have a few of those on OCN already.
All i did was find the deal!
Also any reason why your buying a retail boxed CPU and an aftermarket cooler? Could go OEM and save a few bucks.
OR even better just unlock a sempron and save another couple dollars
1 - 20 of 22 Posts
