1 - 15 of 15 Posts
What do you guys think?
I already bought the 2600k and one of the 570's. what do you guys think of the rest of the parts?
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115070&cm_re=2600k-_-19-115-070-_-Product
Video Card - 570
2x http://www.newegg.com/Product/Product.aspx?Item=N82E16814130620
PSU Corsair 850HX
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139011
RAM Corsair Dominator
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145313
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128480
Keeping sig: harddrives, case, soundcard, wirelesscard, h50 cpu cooler, optical drive
Wow, looking very nice indeed. However one or two suggestions.
Corsair Dominator is 1.65V while SB is like max 1.6V!, go for Corsair Vengeance instead.
Why not go for Maximus extreme? Its got a more, extreme look, but that's just me.
If you can fork out so much money, why not get AX850?
· Premium Member
Didn't even notice that. Correct, you want to get RAM that's under or at 1.6v.
Discussion Starter · #6 ·
Thanks for catching that
so this?
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233144
and this?
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139015
also, the Maximum extreme is sold out on newegg, plus the I need at PCIe x1 slot for my wireless card (though I use LAN) and a PCI slot for my soundcard, which it doesn't provide.
· Premium Member
Perfect!!!
The Vengeance RAM is amazing, I have it in my sig rig below. Only gripe people have with it are its timings.. But I don't overclock RAM usually, I just get it stable at advertised timings and voltages after I overclock my CPU.
Discussion Starter · #11 ·
Originally Posted by Rabbs
SB can do 1.65v, dunno why there telling you it can only handle 1.6v. I am assuming this is a gaming rig only, so make sure to disable hyper threading in bios when you get it. You'll only need 4, not 8. Far as the ram goes-i got the same ram, and got 7.9 in WEI.
How would disabling hyperthreading help me?
It will help OCing, and lowering temps when you don't need 8 threads if you're just gaming. If you're just gaming that's why i said to disable hyper-threading, cause it's not needed and like i said will lower temps when OCing.
· Premium Member
As Rabbs said, it lowers temperatures since you'll only be using 4 cores instead of 8 virtual cores. I chose to keep mine on because I don't only use my 2600k to game. I encode, make GIFs, produce, run heavy software, etc.
Fixed for clarity. The i7 is not an 8 core CPU.
1 - 15 of 15 Posts
