1 - 20 of 20 Posts
I'm pretty sure I can get to my Windows (NTFS) drives through SuSE 10.2, right?
I've done it before, so how do I do it?
Originally Posted by Mad_Handlez89 View Post
When I did it I accessed it throught the ROOT folder, cant remember any specifics though
I tried that, can't find it.
I think if you're on a Reiser (spelling) patition for Linux, then you can read NTFS but cannot write to it.
Discussion Starter · #6 ·
I found this, its not specific to your partitions but It could help you
Open the terminal windows
Hope this helps
Nope, didn't work.
[email protected]:~> mount /dev/hda1 /windows/c
mount: dette kan kun root gøre
[email protected]:~> sudo mount /dev/hda1 /windows/c
mount: mount point /windows/c does not exist
[email protected]:~> sudo mount /dev/hda2 /windows/c
[email protected]:~> sudo mount /dev/hda3 /windows/c
[email protected]:~> sudo mount /dev/hda4 /windows/c
[email protected]:~> sudo mount /dev/hda5 /windows/c
[email protected]:~> sudo mount /dev/sda1 /windows/c
[email protected]:~> sudo mount /dev/sda2 /windows/c
[email protected]:~> sudo mount /dev/sda3 /windows/c
[email protected]:~> sudo mount /dev/sda4 /windows/c
[email protected]:~> sudo mount /dev/sda5 /windows/c
How do you take a screenie anyways?
Okay, I got it mounted, but it says:
Couldn't access the folder /windows/c
Does that mean that I need to somehow configure it?
Discussion Starter · #9 ·
Originally Posted by ENTERPRISE1701 View Post
Sounds like you need to Specify Admin rights for acces to that Folder..However this can only be done in Windows..This will help you : http://www.linuxquestions.org/questi...d.php?t=381667
Yeah I figured that out in like 2 minutes.
Now the problem is to how I read the subfiles, LOL.
I picked up a nifty little program called NTFS-3G, using YUMEX. It lets you read and write to NTFS drives, although it recommends that you DO NOT write to system files and such.
So far it works a treat, I haven't figured out how to auto-mount yet though.
You could change the permission rights in Linux too using chmod, so like:
chmod 777 -r /windows/c
And probably the better way is to just add a line to /etc/fstab that way the permission right don't need to be changed. The user who mounted it is given full permission.
I don't believe you'll be able to write to the drive right now though in linux. Thats way NTFS is a pain to work with.
Just install the NTFS kernel module and do it that way. SIMPERL
EDIT: If that was a stupid comment, forgive me. I didn't read the posts...at all >_<
*cough* its spelt kernel
Yeah. linux-ntfs rocks. YAST for kmod-ntfs, that should do something similar. I'm assuming that the naming convention isn't too different from fedora and debian.
Speaking of NTFS and linux. This whole dealy with M$ and Novell might make the write support 100% safe. I mean, theres gotta be some give and take. You could always do what I do. Install XP into a Fat32 partition. It has its limitations, but I dont care.
Discussion Starter · #16 ·
Okay guys, I'm not on that rig right now, but I got it all working fine and dandy, I only need to get WINE installed, and copied some games over to my Linux partition...
Yeah I have windows in NTFS, and then have an external drive that is in FAT32 and I use that as my share between the two.
I hope that the M$ and Novell deal does lead to some good things for those of us who use both.
Originally Posted by Jimmy2Shoe
Ummm... I can write to a NTFS partiton from within Linux... is there something I'm missing?
Well, you are able to write to a NTFS partiton, its just that in the past its been shown to not be 100% safe. Non-bootable windows partition.
Oh, ok... thanks for the clarification
I'll probably still do it, my data isn't critical anyways.
1 - 20 of 20 Posts
