1 - 3 of 3 Posts
I was wondering if there was any existing component in the Accessory Mounting System that would allow me to put a short 5.25" device (such as an Aquaero 6) in my X2M given that I have all front flex bays filled with two 4xHDD holders.
I am aware that there was a X2M build log showing molded perspex but I wondered if something was already available. Maybe a pair of vertical mounts spaced the correct distance with the 5.25" facing the case side? I don't need access to it from the outside of the case as the Aquaeros are fit, configure and forget.
I have something like that in my NAS build log (see sig). I added a hidden fan controller that is only accessible if you take the side off. I used two short mounts but added holes so that the fan controller is slightly pointing upwards.
1 - 3 of 3 Posts
